oil leak???
Old Apr 28, 2011 | 09:33 PM
egbandman's Avatar
Default oil leak???
1992 Honda Accord 2.2l engine there is an oil leak coming from the back right side of the motor bellow the valve cover. It looks like a PCV valve. Can someone take a picture of their engine and point it out then, if you could tell me what this is so I know what to fix :-) thanks in advance.
Old Apr 29, 2011 | 07:38 AM
If this is a Vtec engine, it may be the Vtec solenoid presssure switch that is leaking. There's an oring seal under the switch that hardens and leaks w/age. Post details of your vehicle and trim in your signature line so it's always there.
Old Apr 29, 2011 | 07:05 PM
egbandman's Avatar
it's the 92 accord ex with the 2.2l motor no v-tec
Old Apr 29, 2011 | 10:46 PM
When you say "back-right side of motor" do you mean passenger or drivers side?
The driver's side has a oil pressure switch near the oil filter. They are prone to leak through the switch central core.
Old Apr 30, 2011 | 05:57 AM
egbandman's Avatar
it seams to have a lot of leakage around the timing cover and under the distributor... I thought it was from a switch it's not it's around these areas... would that be a bad camshaft seal?
alltime3rdwheel
Dec 31, 2012 10:46 AM
frost506
Jan 16, 2012 07:21 PM
MiyashiMeism
Sep 5, 2010 02:12 PM
mamtsberg
May 30, 2010 07:04 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
