Oil Pan Gasket
Old Nov 9, 2011 | 03:22 PM
jfidelh's Avatar
Yeah it was all together, one big piece. Im actually going to check the ground on it, even make a ground wire just to test it, maybe it has bad ground, ill post some pictures up in a bit to see if it goes how I have it set up cause you can tell the previous owner messed with it.
Old Nov 9, 2011 | 06:03 PM
jfidelh's Avatar
I followed the ground wire from inside the assembly to the pin that leads to the outside connector and turns out the problem was the ground. I guess the assembly grew tired of the old ground so once I hooked it up to the ground I use for my amplifiers just to test it.
Although it only rose to 1/4 in about a 2 minutes but I didnt want to waste gas so I turned it off, hopefully it rises more on the way to the gym since I did put $20 yesterday.
Old Nov 9, 2011 | 06:11 PM
jfidelh's Avatar
Originally Posted by bigpat
You can keep track of your miles driven using the trip odometer. I know when I reach 325 miles, I need to fill up.
I know, I've been doing that but I am the type of person that likes evrything working or else it bugs them. lol
Old Nov 9, 2011 | 10:55 PM
jfidelh's Avatar
This didnt help, just left it stuck at 1/4. The search continues
Old Nov 13, 2011 | 12:36 AM
jfidelh's Avatar
Okay, so it did work after all but I re-cut the wires from the ground and scraped the paint off with a dremel then screwed the ground onto the frame with a screw and a nut. FIN end of story :P
ccookie66
Apr 12, 2019 04:43 PM
frost506
Jan 16, 2012 07:21 PM
meazz1
Feb 21, 2006 09:25 PM
mcrisost1999
Jul 10, 2005 07:13 PM
Shocker
May 4, 2005 02:03 AM
