OK to drive car w/ a/c compressor jumper wire?
Old Sep 9, 2013 | 02:38 PM
primolee's Avatar
Question OK to drive car w/ a/c compressor jumper wire?
Hi, I an new to Honda's, just bought a '94 accord lx and while getting things working I had to replace the a/c comp. and dryer, after recharging the compressor would not turn on so I did some research and made a jumper wire from the battery to the compressor clutch and it started up and ran ice cold. My question is can I run the a/c temporairily with the jumper wire just until I check all of the relays and switches( maybe 50 miles) so I can see if I have any leaks ?, or will it do damage to the system. I have a switch inline on a jumper wire right now. Any help is appreciated. Thanks, Bill
Old Sep 9, 2013 | 03:07 PM
There may be some problems, but w/ care it should be OK.
Compressor will be engaged whether AC switch is on/off or blower is on/off. If you forget and run w/ blower off, compressor may overload and damage. Also cooling fans won't come on unless you jumper thermoswitch A to force them to run all the time w/ keyswitch On.
AC may freeze up as thermostat will not be able to open compressor relay when evap temp goes below freezing.
Old Sep 9, 2013 | 03:18 PM
Seems to me that you should not allow the compressor to run for extended time. Even if you wire the radiator fans to run 100%, you should not allow the compressor to run 100%. When the system operates correctly, the compressor cycles on & off so it only runs 20% or 50% of the time. You risk allowing the high-side refrigerant pressure to get too high.
Old Sep 10, 2013 | 09:07 AM
primolee's Avatar
Hi, Thanks for the replys, these answers make a lot of sense and I will fix all of the problems brfore I run the A/C . Thanks Again, Bill
ak474u
May 4, 2015 11:15 PM
cadams8221218
Jul 15, 2011 07:24 AM
churritos567
Jul 26, 2010 07:53 PM
overflow29
Apr 2, 2009 07:02 AM
thunder_x
Mar 24, 2008 04:48 PM
