P1457
Old Apr 9, 2007 | 01:05 PM
BLuEPiTBuLLz's Avatar
Default RE: P1457
My friend says that when he resets the light goes off for awhile and he said he can floor it and it wont come on but when he stays steady at 40-45 MPH it throws it back on.... where is the CVS valve you were talking about located?
Old Apr 9, 2007 | 02:31 PM
Default RE: P1457
There may be substantial differences between your '97& my '98.
My EVAP canister is located under the car, roughly below the left-rear seat. The CVS valve is on the outboard end of the canister.
The EVAP errors are funny. I think the system works like this... Every once in awhile the ECU needs to check whether the gas tank & EVAP system is airtight. So it closes a couple solenoid valves & waits for the gas tank to begin pressurizing itself (gasoline's vapor pressure). It watches the gas tank pressure sensor.
If this doesn't work, it doesn't set the CEL yet. If it fails 2 (or 3?) times in a row, THEN it lights up the CEL & sets the error code. If I reset mine it would stay offfor a day or 2 under normal driving habits.
Old Jul 14, 2007 | 01:50 PM
bougie_44's Avatar
Default RE: P1457
i got the same code, i reset mine and it came back after 5 days. My mechanic with out looking at anything just told me to replace the vent shut valve and canister. With this p1457 code i also got a p 0420 code which has to do with the cat. and my mechanic told me to replace the o2 sensor b-1.
well should i listen to my mechanic or tel him about this discussion? Well i also found a honda bulletin but i think it applies to automatic cars, mine is 5 speed ( 98 accord 2.3L) well here it is:
http://www.driveaccord.net/forums/at...p;d=1107021677
Old Jul 14, 2007 | 02:05 PM
bougie_44's Avatar
Default RE: P1457
P1457 won't make the car run bad at all. It just means the EVAP canister & the related system of hoses & valves isn't airtight.
Check this stuff in this order. As soon as you find something that doesn't behave like it should, fix or replace it. Then hope it was the only thing wrong with the system...
Some background for the electrical troubleshooting:
All the solenoid valves have constant +12v supply from the main relay. When the ECM wants to energize a valve, it closes the ground side of it's circuit. If the +12v supply is broken, then the ECM can't energize the valve. If the wire to the ECM is shorted to ground, then the valve is energized even when the ECM doesn't want it to be.
EVAP Purge Control valve - between intake manifold & valve cover.
Valve should be normally closed, so it will hold vacuum when it's not energized. Ground is supplied by pin A6 of the ECM to open the valve. So jumper pin A6 to ground, turn on the ignition, and check again - this time it should NOT hold vacuum.
EVAP 2-way valve - underneath the car roughly under the left-rear seat.
It's a little can with 3 hose barbs & a solenoid valve attached to it. Leave the connection on top, disconnect both on the side, attach MityVac to lower one. Normally open, when the solenoid valve is energized, it should hold vacuum.
EVAP Vent Shut valve - attached to the charcoal canister underneath the car.
Normaly open - when ECM closes pin A4 to ground, it should hold vacuum.
EVAP Charcoal Canister - the big can under the car, about under the left-rear seat.
Leak test: Connect all the hoses together, plug the Vent Shut valve, connect the MityVac. Pump vacuum while watching the fuel tank pressure (FTP) sensor. You can read FTP sensor voltage with a scan tool, or use a voltmeter between pins A29 & C18 at the ECM. Pump down to 1.5v & it should hold that vacuum for at least 20 seconds.
EVAP 2-way valve vacuum & pressure test.
If you get this far you'll want the manual for a good picture of how to connect the hoses. Keep pumping the vacuum pump & it should stabilize between 6 & 16 mm Hg of vacuum. Then pump pressure, it should stabilize at 8 mm Hg or more of pressure.
Then there's a test of the ORVR Vent Shut valve, which is located on top of the gas tank. You check vacuum & pressure at a couple hoses alongside the fuel filler pipe. If the valve is bad you drop the gas tank to replace it...
Old Jul 14, 2007 | 02:40 PM
Chiovnidca's Avatar
Default RE: P1457
ORIGINAL: JimBlake
That's close. The pcm energizes the purge control solenoid to draw a slight vacuum on the system. If it detects a leak it uses the bypass solenoid to determine if its on the tank or canister side. It's a 2-trip code.
Old Jul 15, 2007 | 04:28 PM
Default RE: P1457
ORIGINAL?: bougie_44
The details in the rest of your post arefor '98-2000 but we've got a '97 in this thread too. Be careful how much of the details change between 5th and 6th generations.
Niteshade
Jul 25, 2013 09:57 PM
mbarnes1982
Apr 3, 2008 09:37 PM
ajluu
Jan 3, 2008 12:51 PM
lucky777
Dec 4, 2007 08:47 AM
zoominhuman
Mar 30, 2007 06:55 PM
