PLEASE! I NEED 94 Accord Speedometer VSS HELP!
Old Dec 1, 2014 | 10:20 PM
  #61
The part is the differential assembly. Behind the final driven gear is the differential carrier (which are both parts of the differential assembly).
The VSS gear shaft most likely turns with the differential carrier side gear (highlighted in yellow).
Attached Thumbnails PLEASE! I NEED 94 Accord Speedometer VSS HELP!-differential-assembly.jpg   PLEASE! I NEED 94 Accord Speedometer VSS HELP!-differential-assembly-2.jpg   PLEASE! I NEED 94 Accord Speedometer VSS HELP!-differential-carrier-gears.jpg   PLEASE! I NEED 94 Accord Speedometer VSS HELP!-differential-carrier-side-gear.jpg
Old Dec 2, 2014 | 10:51 AM
  #62
joe94wag's Avatar
Hey Redbull, Thanks for chiming in! That is definitely the culprit! Now, the question is: What caused that gear to become dislodged from it's mooring, and is it something I should consider repairing, or just find meself a good used tranny and swap out?
This forum rocks. Thanks fellas!
Old Dec 2, 2014 | 11:50 AM
  #63
There may have been an issue with the differential bearing to cause it.
Is the differential gear damaged (e.g., teeth broken, etc.)? -- I didn't read this whole thread. :P
If the issue was due to the differential bearing and/or outer bearing race, those can be replaced.
But, if the differential carrier gear is broken, it would be harder to find just the differential carrier. Probably would have to be used. Honda doesn't sell it anymore, they use to only sell the whole differential carrier and not the gears that were part of it.
Depending on what the underlying issue is (e.g., differential bearing) and what may or may not have been damaged (e.g., differential gear), a used whole good transmission may be more cost effective (if you can find one for a good price) and easier to replace.
Old Dec 2, 2014 | 09:15 PM
  #64
joe94wag's Avatar
Thank you, Redbull. I suppose I may never know why that gear failed, but in the interest of time and money, I'm shopping for a used tranny. Looks like about $500. for JDM in the SF bay area.
All the best!
Old Dec 5, 2014 | 05:30 PM
  #65
joe94wag's Avatar
Default Trans. Fluid Procedure?
I will be picking up a JDM used transmission this weekend, and wondered if I should just fill it with new fluid, or do a 3x's flush? What is the capacity of the Accord 4 cyl. auto tranny when empty?
THANKS!
Old Dec 5, 2014 | 05:39 PM
  #66
Service manual for USDM auto transmission specifies 6.3 U.S. quarts for overhaul.
2.5 U.S. quarts for fluid change.
Old Dec 6, 2014 | 10:04 AM
  #67
joe94wag's Avatar
Many thanks!!
Old Dec 6, 2014 | 11:01 PM
  #68
joe94wag's Avatar
Default F22B Transmission cooler lines
Can anyone tell me which line is the transmission cooler inlet (and which is outlet) on my 94 F22B auto trans. I want to flush the tranny cooler before I install trans, and have been told to back flush.
Thanks,
Joe
Old Dec 7, 2014 | 12:08 AM
  #69
See attached image.
Attached Thumbnails PLEASE! I NEED 94 Accord Speedometer VSS HELP!-atf-cooler-lines.jpg
mrmiller99
Sep 27, 2019 02:26 AM
PeteGibson
Jun 27, 2014 02:34 PM
mrmiller99
Jul 2, 2011 07:07 PM
comptoncarl
Feb 8, 2007 03:04 PM
cbriley3
Oct 23, 2005 11:04 PM
