Power steering return tube '99 sedan
Old Jul 27, 2012 | 11:50 PM
tobytigger's Avatar
Default Power steering return tube '99 sedan
In the process of replacing the crank pulley, timing belt, seals, I sprung a leak in the return line. Two plastic clamps were broken so the tube moves freely but I was careful to not move the line. On a cross member near the firewall is a clamp with a rubber bushing with a badly rusted screw & nut and that is where the leak is. Looks like the rust grew around the tube to the frame and the leak is on the bottom of the tube. I tried to remove the nut but it wasn't moving so soaking it with PB. My guess is there is a pin hole on the bottom of the tube.
The problem is Honda discontinued the part. Can I replace the tube with a hose or brake line? I've been to the junk yards over the past 2 year's and finding an Accord from 1998 on is impossible.
Old Jul 28, 2012 | 01:06 AM
my1st.honda93's Avatar
so whats your question?if you want to know what to do about the leak?replace the line!
Pick-a-part or those junk yards that let you pull your own parts is a least expensive way to go if your a DIYer if not auto parts store!
Old Jul 28, 2012 | 09:36 AM
Or to your point, if the rubber piece is not a special molded hose you can use a longer hose that will slide up over where the metal line has a hole in it and clamp it......or cut the metal past the hole and clamp?
dpotter
Dec 16, 2013 12:51 AM
lp284
Oct 28, 2011 07:25 PM
BlueJazzWing
Jul 5, 2007 04:19 PM
suprarx7nut
Jun 21, 2007 12:03 AM
45auto
Mar 28, 2006 02:59 AM
