Problem
Old May 28, 2012 | 08:53 PM
Kim Phung's Avatar
Default Problem
Hi. I have a 1994 for honda accord ex. This morning my speedometer was not moving. Then a min of driving my D4 light starts flashing (blinking) then i kepted driving cause that happen before about 3 days ago. After another min of driving my Check Engine light turns on. I turned off my car and turn it back on. Everything was fine but speedometer acts up. it did that about a week now. Like ill be at a constant 40 then all of a sudden it will drop to zero then jump back up to 40. What it wrong with my car?
Old May 30, 2012 | 12:11 AM
You should have posted in the General Tech Help section. It may turn out to be the Vehicle Speed Sensor (VSS), connection or wiring. But, first you should get the trouble code to narrow down the problem to be sure. Under the passenger side dash, there is a blue connector that you can jump with a small paper clip or wire to retrieve the trouble code by counting the sequence of blinks of your Check Engine Light and/or D4 light.
Go to the General Tech Help section and at the top of the sticky are links to info. on retrieving the trouble code(s).
Old May 30, 2012 | 06:10 PM
You should have posted in the General Tech Help section. It may turn out to the Vehicle Speed Sensor (VSS), connection or wiring. But, first you should get the trouble code to narrow done the problem to be sure. Under the passenger side dash, there is a blue connector that you can jump with a small paper clip or wire to retrieve the trouble code by counting the sequence of blinks of your Check Engine Light and/or D4 light.
You are right on all accounts my friend....I've moved this.
OP- Please follow the advise given and let us know from there.
trouble
Aug 21, 2012 07:46 PM
jkrueger2020
Mar 10, 2011 02:18 AM
kellysa111
May 1, 2009 08:35 AM
mahones
Oct 13, 2008 08:24 AM
92Inspire
Aug 13, 2006 03:37 PM
