Problem with Keyless Entry Accord 2004
Old Sep 30, 2015 | 04:13 AM
Mahmoud Muhammed Selim's Avatar
Exclamation Problem with Keyless Entry Accord 2004
back in 2014 i bought a keyless remote for my Accord 2004 in Kuwait, it was programmed easily at the locksmith and it worked for 1 day, then it didnt work.
i returned it back and since a couple of month i tried more than 100 other remotes and no one worked.
anyone knows where is the fuse of the keyless entry and how to repair such a problem ?
because it worked only for one day then it stopped working with a remote last year, i am doubting the receiver.
the receiver in many cars has either a fuse in itself or connected to a fuse.
i need help
thanks
Old Sep 30, 2015 | 03:32 PM
Prospector's Avatar
First of all, welcome to the forum Mahmoud
Secondly, which trim level is your Accord? LX of EX?
Old Oct 1, 2015 | 01:59 AM
Thanks a lot
I Actually don't know
it is a 4 door, 2.4 i-Vtec 4 cylinders
manufactured in 2004
here is some images..
Attached Thumbnails Problem with Keyless Entry Accord 2004-main-1-.jpeg   Problem with Keyless Entry Accord 2004-main-6-.jpeg   Problem with Keyless Entry Accord 2004-main-7-.jpeg   Problem with Keyless Entry Accord 2004-main-4-.jpeg
Old Oct 1, 2015 | 10:19 AM
Prospector's Avatar
Good looking car, appears to have been well maintained
As you are likely aware, remotes are vehicle (and year) specific, it is possible that the locksmith may have inadvertently substituted a different model year. If the receiver is operational, then a software update could be advisable.... You may need to contact a Honda dealership.
In the meantime, here are some instructions for setting the remote:
Entering the programming mode cancels all learned keyless remotes, so none
of the previously programmed remotes will work. You must reprogram all of the
keyless remotes once you are in the programming mode.
You must complete each step within 5 seconds of the previous step to keep the
system from exiting the programming mode.
1. Turn ignition switch to ON (II)
2. Press the LOCK or UNLOCK button on one of the remotes. (An un-programmed remote can be used for this step.)
3. Turn ignition switch to LOCK (0)
4. Repeat steps 1, 2 and 3 two more times using the same keyless remote used in step 2
5. Turn the ignition switch to ON (II)
6. Press the LOCK or UNLOCK button the same remote. Make sure the power door locks cycle to confirm you are in programming mode.
7. Press the LOCK or UNLOCK button on each remote you want to program. Make sure door locks cycle after you push each remote button to confirm system has accepted the remote.
8. Turn the ignition switch to LOCK (0) to exit programming mode.
9. Test remote(s)
Old Oct 5, 2015 | 06:41 AM
I tried all of this.
i also disconnected teh battery for 13 hours and connected again and it didnt work as well (even the cd player didnt request a code)
What to do ?? i am sure of the frequency of the key.
mikejones305
Oct 2, 2015 04:26 AM
KeystoneKid
Nov 5, 2010 01:15 PM
jimmy
Aug 2, 2009 10:36 AM
bryanboling
Oct 29, 2007 01:08 AM
93Miata
Nov 10, 2005 08:06 AM
