Q. re: bleeding brakes vs. ABS system
Old Sep 1, 2012 | 12:41 PM
Pajamarama's Avatar
Default Q. re: bleeding brakes vs. ABS system
Hello --
I am looking to replace the brake fluid for the car listed in my sig.
I have been reading the Helms manual to find information on this process. The Brakes section has 2 sub-sections: Brakes and ABS.
I've been trying to figure out how the two sections correlate in regards to bleeding/fluid replacement. Do I bleed all the individual brake lines first and then the ABS reservoir, or the other way around? Any input on the correct order would be appreciated. Thanks.
Old Sep 1, 2012 | 01:18 PM
Personally, I would probably do the ABS first, but I do not think the order would matter much.
Old Sep 1, 2012 | 03:21 PM
What Accord? They have different systems in later models.
Up to about 1997 they had a reservoir. You could remove/refill the fluid and not require any bleeding, but would leave a small amount of old fluid in the modulator. If you progressively crack the bleeder, you should remove all the old fluid.
Bleeding main brakes w/ ABS is same as non-ABS; replace reservoir fluid and progressively bleed each while while topping up reservoir as necessary.
Wrenching
Aug 1, 2014 06:13 PM
big boi
Jan 13, 2014 08:33 AM
deserthonda
Mar 30, 2013 01:11 AM
AngelFisher27
Jun 21, 2011 08:32 PM
BlueByYou
Oct 8, 2006 01:43 AM
