Question...
I just replaced my lower rad hose, and therm housing and sensor. (i had a aftermarket housing and i think the wrong sensor in it) Pretty easy and straight forward, altho i didn't get the system to burp correct, i'll try again in a few days,... some observations my heat took a while to get hot, my cold is not as cold as it usually is, but could be that we are experiencing 100+ heat the last few days, and may be just me.
Now my question, i have a oil leak, so i thought i'd poke around while i was under car, wouldn't you know it, my oil pan was loose, every screw that i could reach or get at was loose, I tightened them, BUT i didn't tighten them how i should have, had i replaced gasket. There were 2 or 3 nuts that i just couldn't get to. So, should I go back under and loosen, and then retighten per directions?? or not worry about it?? What do you all think?
Thanks!
Thanks!
Torque spec is 10 ft-lbs or 120 in-lbs, so not much torque required. These tend to loosen w/ ageing of gasket. My experience was that tighening did not stop leaks. I eventually installed a new gasket to fix.
And I agree with TH on his post..
Stopormymomwillshoot
Aug 29, 2010 06:18 PM
greg05
Aug 17, 2009 08:22 AM
