rear door latch clink
Old Jan 27, 2016 | 08:28 PM
jkowtko's Avatar
Almost A Senior Member
Default rear door latch clink
Hear the clinking sound? Sounds like it's coming from inside the latch itself. Is this fixable? Or just buy a new latch?
Thanks. John
Old Jan 27, 2016 | 09:34 PM
Since the latch works, you can try lubricating it with some white lithium grease. That noise might be coming from the metal bar that prevents the door from swinging completely open. Its not in the same place, but location of the noises can be tough to pinpoint. White lithium grease on that part is simple to try and somewhat common problem.
Old Jan 27, 2016 | 10:54 PM
jkowtko's Avatar
It doesn't sound like the latch lever against the striker plate. It sounds like there is something inside the latch mechanism -- maybe a spring-loaded piece where there spring has disconnected?
I believe you are talking about the door check strap, in front by the hinges. It's definitely no the check strap -- that would make a different type of sound and you can definitely tell where it's coming from.
Old Mar 5, 2016 | 04:17 PM
jkowtko's Avatar
I figured it out. Turns out the rotating latch plate itself is metal covered with a 1-2mm plastic shell (see picture) ... and on my car the plastic cover had become brittle over time and broken off, exposing the metal on the inside. It was the metal on metal that was clinking.
Purchased a used latch on eBay for $15 plus shipping, and just put it in today. Noise gone
bmarz
Aug 15, 2013 06:52 AM
jza240sx
Apr 30, 2013 04:14 PM
bigdawg74
Mar 31, 2013 08:39 AM
RedLineZ_05
Oct 18, 2012 09:24 PM
kc0jsj
Oct 30, 2011 12:22 AM
