reoccuring headlight problem
Old Feb 27, 2014 | 08:44 PM
ndubg's Avatar
Default reoccuring headlight problem
i have a 2005 honda accord that i purchased back in nov.2013.
Shortly after buying it the passanger side headlight went out. So i bought a new set. A few weeks later the drivers side goes out even though it was a brand new bulb from the set i bought . Got a whole new set then yesterday the passanger side went out again. tested the bulb and it was no good.
So my question is- What is causing the headlights to blow and how to i fix/find out what is causing them to blow out?
Old Feb 28, 2014 | 09:11 AM
Vibration can cause premature failure. Also excess voltage (alternator regulator problem) could cause premature failure.
check mounting for security and suggest purchasing a battery voltage monitor (equus $15) from walmart to monitor battery voltage. It should never exceed about 14.5 volts and usual range is 13.5-14v.
Old Feb 28, 2014 | 10:51 AM
Check the little rubber button-things where the front of the hood closes. Are they adjusted so tight that you have to slam the hood closed?
lyle
Jun 4, 2008 12:36 PM
Equalizer
Oct 24, 2007 08:11 PM
jbl2bgone
Mar 6, 2007 01:04 AM
96accord
May 15, 2006 11:35 PM
