Retractable Headlight problem
We have a 1989 Accord LX withe the retractable headlights, we were replacing one side and when we re-connected the fuses we have one up and one down!
Tried a few things but still have issue - would appreciate any tips!
Hey guys. I had a problem when installing a new headlight on the right side. I was in an accident and had to hammer out the fender rail and fender well. I removed many components to do so. When I finally got the headlight and headlight motor installed, I plugged it and tested it before I completely reassembled all the components. The moter and headlight were used so I figured I would test them before everything went back together. This is where I made my mistake. My symptom was that the when I turned on the headlights, the right headlight (battery side) kept going up and down over and over. Same when I turn the headlights off. Had to disconnect the battery to make it stop. Also no light out of either headlight. (the left headlight retracted perfectly). Upon further investigation, I discovered that the motor was not operating in up/down but was operating in up only. Since the lever and joint are circular, it appeared that the motor was operating in up/down but is was only going up continuously which in turn made the headlight go up and down.
After checking voltages and relays, fuses and the retractor control unit. I found out through the shop manual that the ground for the system is through two small modules mounted under the fuse box( which i had removed and not reconnected). This ground is a module to body ground by way of a bolt. The modules are small and off white and are mounted to the same bracket that the fuse box is mounted to. They look like plugs. They are grounds G201 and G202 in the manual.
After I bolted these things back up, my right headlight began to retract perfectly. Both headlights came on and everything was back to normal. So if anyone is having this problem, check the grounds.
I have had alot of help from these forums so I just wanted to throw this out there because it took me aloooong time to figure this out(with Gods help
....). It was a big headache. Hope this helps. Good luck everyone.
I'll keep this comment up just incase it helps some how.
dmanster1
Apr 8, 2013 08:11 PM
WindPhoenix
Aug 7, 2012 11:45 AM
djstylze
Nov 2, 2006 02:08 PM
