Reving tranny?? is it time to rebuild?
Old Aug 29, 2013 | 03:46 PM
justing920's Avatar
Default Reving tranny?? is it time to rebuild?
I have a 94 accord with 195k auto just happened today i was driving home nd as the gears shifted from 1to 2 it revs for a while then shifts same from 2 to 3rd but that rev is longer is my tranny goin bad. I cant afford for it to go bad right now. It doesnt sound good any ideas ?
Old Aug 29, 2013 | 04:10 PM
Dr. Drivability's Avatar
checked the fluid yet?
Old Aug 29, 2013 | 04:23 PM
justing920's Avatar
No i havent but i had filled it a while back ill check on it when it cools down
Old Aug 30, 2013 | 04:29 PM
I hope they used Honda Trans fluid........
Old Sep 5, 2013 | 10:48 PM
justing920's Avatar
Did not use honda atf but still does the reving think its time to rebuild
Old Sep 5, 2013 | 11:00 PM
Check the engine codes. The common diy thread on top of the gen tech help forum has a link to get the CEL or D4 codes.
If money is an issue, buy 3 quarts of Honda ATF, then do a drain/refill. That common diy thread has a link for free online shop manuals. We can give some more information if you need it.
Old Sep 5, 2013 | 11:55 PM
justing920's Avatar
I have ran codes nd got these d4-15 abs-13 cel is tricky i got 9 short flashes first followed 3 long after. So its not 93 so i assume 9 and 30 ? But i will take a look into the manuals or get an estimate from a shop
Old Sep 11, 2013 | 07:22 PM
skipbroussard's Avatar
You might consider a used tran 2006 and up. They'll fit.
Old Sep 11, 2013 | 08:15 PM
Do not listen to the post above me. An 06 transmission will not fit on your 94 accord. And do not replace your transmission.
The D4 code 15 is for the mainshaft speed sensor.
The CEL code 9 is for a sensor in the distributor.
The CEL code 30 is a communication problem between the ECU and TCU.
Take a look at the electrical connectors for the mainshaft speed sensor, the distributor, the ECU and TCU for a loose connection.
darshan
May 14, 2013 03:34 PM
First90AccordMan
Jan 14, 2012 02:43 PM
Et5291
Dec 24, 2009 11:06 PM
Joshporsche
Jun 14, 2006 10:07 PM
Jimmydageek
Feb 23, 2006 03:24 AM
