Right side brake light doesn't work
Old Mar 12, 2007 | 08:04 PM
TexasCJ7
Default Right side brake light doesn't work
I changed the bulbs and even tested the removable console that holds the bulbs on the other side. The turn signals and parking lights work on the right side, but the brake lights on that side do not work. Any thoughts?
Thanks in advance,
1991 honda acoord LX 2.2
Old Mar 12, 2007 | 08:05 PM
sir_nasty's Avatar
Default RE: Right side brake light doesn't work
providing the left side works make sure it's grounded (there should be a short ground wire back there I believe)...
Old Mar 12, 2007 | 08:13 PM
TexasCJ7
Is there just one ground wire for both right side bulbs? There is a brake light on the deck lid and 1 on the rear panel.Would the ground wire be buried before its splits off?
Old Mar 12, 2007 | 08:29 PM
sir_nasty's Avatar
Here's some test procedures to try as well...
[IMG]local://upfiles/3079/375A828DCE7E49868A7C9C76E1A2DFBF.jpg[/IMG]
[IMG]local://upfiles/3079/3E016D85D42E4BFFA23EFAD57320E44A.jpg[/IMG]
Old Mar 12, 2007 | 08:53 PM
TexasCJ7
Thaks for the info, I'll check it out.
Old Mar 12, 2007 | 08:58 PM
sir_nasty's Avatar
Let us know what you find and if you resolve it what the solution was, if you don't resolve it let us know what tests you did so we can help you further....
Old Mar 12, 2007 | 10:35 PM
hondadude's Avatar
Check the bottom of the socket, sometimes the connection solder bump gets flat and won't make contact.
BmxJsh6
Sep 18, 2012 09:58 PM
WindPhoenix
Aug 10, 2012 10:15 PM
MessAround
Dec 3, 2011 08:42 AM
cb7sk8rdude
Oct 29, 2011 12:48 PM
freemoney
Nov 19, 2010 02:30 PM
