Rpms running high...?
Hello
I am new to this so bear with me....heres the problem..
I have a 03 Accord Ex in which the rpms seem to hold steady at 2000+ driving at 55mph and even when I first start it in the morning it stays at 1000...is that average?? I also just has alot of maintenance done which was suppose to fix this but didnt (replaced o2sensor, vtech valve, also oil change new brakes and rotors and new tires..) I used to get about 400+ miles to a tank of gas now Im getting roughly 300+......and I just started using the lucas to help hopefully.. Sooo any suggestions on what could be causing this would be appreciated!!! Thanks!
I am new to this so bear with me....heres the problem..I have a 03 Accord Ex in which the rpms seem to hold steady at 2000+ driving at 55mph and even when I first start it in the morning it stays at 1000...is that average?? I also just has alot of maintenance done which was suppose to fix this but didnt (replaced o2sensor, vtech valve, also oil change new brakes and rotors and new tires..) I used to get about 400+ miles to a tank of gas now Im getting roughly 300+......and I just started using the lucas to help hopefully.. Sooo any suggestions on what could be causing this would be appreciated!!! Thanks!
Its an auto...and not sure what the codes were. The check engine light was on and I was told that was because o2 sensor..I have no lights on now and the car is running good just wondering if that is normal on the rpms
lucidrain
Jul 31, 2013 11:21 AM
cb7sk8rdude
Oct 9, 2011 06:40 PM
Snarfblast
Jun 3, 2009 09:11 AM
Jahsaccordcoupe
Dec 1, 2007 12:06 PM
