Screeching @ Ignition
Old Mar 11, 2008 | 06:32 PM
confuseid's Avatar
Default Screeching @ Ignition
When I turn the ignition on my car, a horrible screeching noise emits from my engine.
I thought it was the timing belt, so I put some WD-40 on it.
However, that did not really do anything.
It sounds like it is coming from the engine, or the headers (but not really)...
I have no clue what it is. The sound is so loud and screeching that it is hard to tell where it is coming from.
Any ideas?
Old Mar 11, 2008 | 07:09 PM
Default RE: Screeching @ Ignition
It could be a loose accessory belt, bad harmonic balancer/crankshaft pulley, cooling fan motor, or other. Unless you want to DIY, you need some qualified help to locate the problem.
PS put your car model and year in your signature line. It' helps.
Old Mar 12, 2008 | 08:13 AM
Fenix's Avatar
also you could be turning the key too long.
AccordLXMaster
Aug 21, 2009 07:38 AM
Jcaleno
Oct 24, 2008 01:54 PM
vmysore
Aug 8, 2008 09:25 AM
dragoneyes
Jun 26, 2007 09:51 PM
trukid21
Mar 6, 2007 10:08 PM
