Small Electrical Issues - 03 4 cylinder EX
Old Mar 18, 2015 | 07:19 AM
simplyjessi's Avatar
Sylvania bulb guide list 1157A.
I happened to throw the packaging in the glove box for the marker lights I bought. Its the same part #. . I'll buy another set today, since they're cheap, just to make sure it wasn't those bulbs.
Old Mar 18, 2015 | 02:15 PM
1. The front bulbs may be okay if you had already previously replaced them; but, it would be good to check the filaments.
2. From what you mentioned regarding the accessory cigarette lighter add-on, there may be a short in the wiring that is affecting the front turn signal/side markers. -- Try this as a test, unplug under-dash Fuse No. 9 (15A), this is the fuse for the accessory power socket relay. Does the front turn signal/side marker go out with Fuse No. 9 pulled?
If it does, there probably is a short in the wiring, where the exposed power wire for the accessory power socket is touching other exposed wiring.
3. I haven't confirmed whether some of the buttons on the climate control system light up or not, even if you did not have the other issues.
Attached Thumbnails Small Electrical Issues - 03 4 cylinder EX-underdash-fuse-box.jpg
blue94ex
May 25, 2013 08:59 AM
Chris Jameson
Feb 19, 2013 06:39 AM
STINKA621
Mar 9, 2009 07:53 AM
importedminds
Jun 20, 2008 05:48 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
