Stalls while driving
Old Mar 21, 2011 | 10:43 AM
TJs Honda's Avatar
Default Stalls while driving
Fellow Honda Enthusiasts,
I own a 1999 Honda Accord 4 cyl. With 140,000 miles.
Car runs like a champ.
I am experiencing a stalling problem on occasion while cruising with the radio on.
Car starts back up shortly after. I have been driving with the radio off & have not experienced the same issue.
Strange has anyone experienced this before?
Looking for help, all the best.
TJ Honda
Old Mar 21, 2011 | 12:27 PM
While I would not rule out the radio as cause of engine stalling, it's very unlikely the cause, and more likely coincidence. You play your radio frequently, and stalling is infrequent, hence it's much more likely that stalling occurs when radio is playing.
Since car starts immediately (?) after stalling, this problem will be difficult to find (problem goes away very quicklly), since diagnostics are not possible.
Stalling while driving can be caused by following based on my experience and posts of others. Both are about equally likely IMO:
1) fuel pump or main fuel relay faults
2) igntion keyswitch electrical fault
When stalling happens, notice whether Check Engine, Alt, and Oil Pressure lights come On (they should) or stay OFF (keyswitch fault likely). This may diagnose the problem
Since diagnostics are not easy, you might consider replacing the ignition keyswitch. Switch is about $50 and 1/2 hr for DIY'r to replace.
Robbinz
Sep 16, 2012 10:14 AM
shula
Sep 8, 2011 03:10 PM
jesseb
Jan 19, 2011 09:08 PM
98-Accord
Oct 24, 2010 11:15 AM
E2Design
Apr 21, 2009 03:49 PM
