Sponsored by:
Sponsored by:
starter problem ??
Old 03-11-2014, 01:23 PM
wc206's Avatar
Went and bought a new coil and it still just cranks over...
Old 03-11-2014, 03:26 PM
Are you getting a spark? Check base timing is correct.
Repeat throttle body starting fluid startup for temporary start.
Old 03-11-2014, 07:17 PM
kris_loehr's Avatar
I would make sure the battery is fully charged and pull the spark plugs and see if they are fuel fouled and if so replace them rather than clean them. Occasionally you get a vehicle that cranks at normal speed but battery isn't charged enough to get proper ignition. I would also check the main ground mentioned by another forum member considering you changed the engine.
trukid21
01-23-2009 09:31 PM
R1ckyB0bbyyy
09-08-2008 01:48 AM
remnam
06-06-2008 10:22 AM
gpsodave
08-29-2007 02:34 PM
fmeier
07-22-2006 02:14 PM
Quick Reply: starter problem ??
