Starting problem
Old Apr 23, 2007 | 09:40 PM
Mulepick
Default Starting problem
Just now completing the install of an H22a with a/t in my 93 Accord Wagon. I've got fluids in it so I wanted to turn it over a few times to work them in and get the trans fluid distributed. When I turn to start, it appears that the starter motor is spinning but not contacting anything. I pulled it and neither it nor the flywheel seem bad or ground down. No missing teeth. Bench tested the starter and it protrudes and spins. When I crank the engine manually at the timing belt, the flywheel moves but I can also move it by hand (easily) through the starter hole. The tranny has mated up OK.
I can't think what's wrong. Hope this is enough info for some advice.
Tks,
Bob
Old Apr 23, 2007 | 09:51 PM
deserthonda's Avatar
Default RE: Starting problem
first of all you mean torque converotr right ??
did you install the 8 , 6 mm bolts that bolt up the flex plate to the torque convertor,??, did you install the flex plate to the engine ??
Old Apr 23, 2007 | 09:59 PM
Mulepick
I never detached the drive plate from the engine. I'll certainly check to see if I attached the torque converter to the drive plate!
Bob
Old Apr 23, 2007 | 10:13 PM
Mulepick
Just pulled the lower cover and checked things out...
In the immortal words of Carlos Mencia...
DEE DE DEE
Tks,
Bob
Yamasaki
Nov 5, 2011 09:19 AM
quack31
Feb 5, 2007 05:07 AM
cyurgeles
Jan 21, 2006 10:36 AM
rev2ninetyper
Nov 14, 2005 04:06 PM
karmajay
Sep 13, 2005 06:57 PM
