Starting problems
Old Aug 23, 2012 | 02:45 PM
Miguelwaterpolo's Avatar
Unhappy Starting problems
Hello I have a 1993 Honda accord EX and have been going through starting problems. I changed the battery, also spark plugs. It has a mind of it's own when turning on sometimes it does other times I have to take off my air filter spray some starter fluid then it's running. Im guessing it's a fuel problem. Any help would be very much appreciated. Thanks.
Old Aug 23, 2012 | 07:16 PM
when you turn the key to start the car, does the starter spin the engine the normal rate and the engine doesn't fire up (run on its own - the point where you release the key)? Or is nothing happening when you turn the key to start the car?
slingnsand
Apr 28, 2012 07:03 AM
applewart
Aug 9, 2006 03:07 AM
hofmeister
May 26, 2006 09:11 AM
KimberlyC
Apr 16, 2006 11:51 AM
ideastoo
Aug 14, 2005 08:30 AM
