starts, immediately dies ecu code 15
Also check to see whether that wire has any continuity to ground (it should not).
Here's a long shot... I've occasionally heard of pins within the wiring plugs that push out, almost the reverse of installing those pins into the big plastic plugs. (especially the plugs right at the ECM) With the pin "retracted", it doesn't make proper contact with the mating socket on the ECM.
But good news!
The used ECM computer from ebay arrived this pm, I fitted it this afternoon and my Honda fired straight up. No hesitation, it's starting fine for the first time in two weeks. After months of having this problem it's finally fixed and a lot wiser about troubleshooting electrical issues.Thank you so much for the great support Jim (JimBlake). Also thanks to poorman212 and MessAround. Thank you for prompting me as to what to check. It helped enormously to know I had such great support and kept me moving through the checks to make progress.
Thank you all
m
Thank you so much and my wife thanks you also, since it's her original car, from back in the day.
mike
twisted95accord
Aug 29, 2011 06:01 PM
