Steering rack
Hello accords and accordians ,
I have a slight issue here , the issue here is , i would like to replace the part that is circled in the diagram , i have no clue what its called . whenever i talk to spare parts person , they have no clue what i am talking about , plus there isnt a way i can send them the picture while on the fone .( Thier not interested in mms ) . Could you tell me what this part is exactly called .
Thankyou all v much in advance and God bless you .
Bye.
[IMG]local://upfiles/14427/5F48A68ADC0C4B8C99D50B6EDB9A8BFD.jpg[/IMG]
Bye.
Thankyou Very much master - I'll have a search on the web and see if i can find any parts - i would assume the only i could purchase this part would be from a honda main dealer . and by the way the 2.0 mm cotter pin you mentioned , does that go at the outer end of the outer tie rod. Thankyou once again .
That part is available at just about any parts store. Usually they will come with a new castle nut as well as any required cotter pins. Your parts store will also have any other cotter pins you might want.
