timing belt cover
Old Apr 11, 2010 | 07:09 PM
gahonda's Avatar
Default timing belt cover
I am tring to determine if i need to replace my timing belt. I bought na 2002 accord se for my daughter and have no records. I took the bolts for the top half of the timing covrr off Needless to say I did not accomplish anything. what do i need to do the cover would not come off it was tight a little help pls thks
Old Apr 11, 2010 | 08:30 PM
How many miles are on the car? You might want to call the Honda dealership to see if they can find the service records in their system.
The valve cover needs to be removed to remove the upper timing belt cover. When inspecting the belt, it may look fine, but may be past due for a change.
If you can not find out when the TB was replaced, then replace it now to ensure that your engine doesn't sustain damage if the belt would break.
mikek
Aug 6, 2019 07:37 AM
john_pyro
Aug 4, 2019 05:06 PM
JohnAccord2007
Aug 13, 2012 08:35 AM
bbdhong
Oct 14, 2007 10:49 PM
Tony1M
Apr 1, 2007 05:42 PM
