Timing Belt replacement
Old Mar 11, 2009 | 11:14 PM
jeepinxj
Default Timing Belt replacement
I have 109k on my V6 01 accord. I know its time to change the t-belt. Has anyone written up directions for this, or does anyone have any resources they could share that explains the steps in replacing the belt, water pump etc.....
Thanks.
Old Apr 1, 2009 | 04:20 AM
norcaldc2
i just finished replacing the timing belt & water pump in my daughter's '01 v6 accord ex with the help of a mechanically inclined friend and a haynes manual. it took longer than we expected due to a balky crank pulley bolt, which too way too much time, but otherwise if you follow the instructions in the manual you should be fine. you might figure between 4-6 hrs, give or take, depending on your expertise. the manual does say to remove the alternator, but we found that it wasn't necessary. there is a section in which you will be instructed to use a part of the battery bracket. make sure you do this. don't forget anti-freeze and good luck.
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
