timing trouble
Old Aug 1, 2011 | 07:45 PM
mrw442's Avatar
Default timing trouble
I have a 97 accord lx with a non vtec 2.2 engine. I replaced the cylinder head and timing belt and I got to timing the engine and I'm having trouble. The first thing is for some reason after loosening the distributor bolts I cant seem to move the distributor unless I take out the front distributor bolt all the way then it will move but the bolt wont go back in after I turn the distributor. And with the bolt all the way out and the connector under the glove box jumped I can move the distributor all I want and it wont change the ignition timing at all it just stays the same when using a timing light. I don't know if maybe I put the timing belt on wrong or maybe I have a bad ignition control module so any help anyone could offer would be much appreciated. I also should note that the car is running fine with the timing not being set and I have no engine codes and I also had to set the valve lash.
Old Aug 1, 2011 | 08:43 PM
mrw442's Avatar
ok after searching for a while on the internet I think I found my answer I read 96 and up accords use a crank shaft sensor and the crows foot on the distributor since u don't have to time the engine.
Old Aug 2, 2011 | 10:11 PM
That's right.
Is your timing off? Or just checking to see if it's OK?
Old Aug 2, 2011 | 11:25 PM
mrw442's Avatar
the car runs great and im pretty sure the timing is fine i just took off the distributor to replace the cylinder head and figured i would have to time it again but i was wrong i didnt know that the distributor on an accord like mine is controlled by the ecm and the haynes manual was no help it didnt say a thing about not having to time obd2 accords. i cant believe the car fired up in three cranks with 8 month old gas and no check engine lights or anything im very suprised i got everything hooked up properly
john_pyro
Aug 4, 2019 05:06 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
Brendo613
Feb 23, 2006 07:26 PM
