tranny swap
Old May 23, 2012 | 06:11 PM
platano_4life_809's Avatar
Default tranny swap
this is my first post on a forum so im not sure how this works but.....
i just bought my first car today. its a 91 honda accord ex.
i was doubting the car at first but relized i really like how if feels.
i really want to switch the auto tranny with a manual tranny. now the moter is a f22a4 and im wondering if i have to use the exact f22a4 tranny, or i can bolt on any f22 tranny or even any f-series tranny?
Old May 23, 2012 | 06:51 PM
crispin's Avatar
Any F series or H series trans will work.
I swapped mine.
even though you have a 4th gen it is basically the same
https://www.hondaaccordforum.com/for...rogress-45489/
Old May 23, 2012 | 06:52 PM
crispin's Avatar
This is a good write-up of what all is required
https://www.hondaaccordforum.com/for...ny-swap-36092/
Old May 23, 2012 | 06:57 PM
good to know thanks. also are all f and h series tranny the same performance wise? if not which ones would you consider better?
Old May 23, 2012 | 08:03 PM
crispin's Avatar
It is debated that some trans have slightly different gears in them but what is for sure is if you plan on a high HP turbo setup you will need to buy a H series with the LSD in it.
However they are expensive and not easy to find.
Old May 24, 2012 | 05:52 AM
The H series M2B4 transmission is probably the best performance. Shorter gear ratios and an LSD. They are known for 5th gear grinds though.
Just putting this in with an F22 you could expect probably .7 second increase in the 1/4 or so.
Old May 24, 2012 | 06:29 PM
thanks for the info. but if the tranny is a obd2 or obd1 woud i have to convert it to work with my obd0 engine?
Old May 24, 2012 | 06:31 PM
also where would i be able to get these trannys. ive been searchng and searching but ive gotten not one link for where to buy one.
thanks for the replies i appreciate it
Old May 24, 2012 | 07:16 PM
Transmission doesnt matter for obd1/2.
You could check an engine importer like tiger japanese or honda engines online. The M2B4 was never in a car sold in America, so any here had to be imported.
You could get just a regular prelude transmission, but it wouldn't have an LSD. The code for these is M2S4.
bigtex
Feb 21, 2018 11:08 AM
tranwreck
Apr 30, 2009 09:27 AM
dannnnnn
Oct 4, 2006 06:37 PM
02SE_VTEC
Oct 11, 2005 05:53 PM
