Turn Signal Switch Help Needed
Old Feb 9, 2014 | 10:02 PM
Jake06's Avatar
Default Turn Signal Switch Help Needed
Recently purchased 2010 Accord and turn signal lever does not set in and hold very well when turning right. It requires a firm push to hold in while the left hand turn holds in fine. Noticed that when the lever is forward on "high beam" the turn signal holds in (latches in) fine. Is there adjustment in the switch to make it work right. Thanks for any help that can be offered.
Old Feb 9, 2014 | 10:39 PM
There is no adjustment. You may just have to replace it if it bothers you too much.
bigdawg74
Nov 4, 2011 10:11 PM
hondaman4lifecg5
Feb 8, 2011 06:21 PM
accordlxi
Dec 17, 2010 02:53 PM
kdozier
Dec 7, 2009 11:30 PM
ZionsWrath
Jan 30, 2008 10:27 PM
