Urgent Help!
Old Oct 31, 2021 | 02:17 PM
HardBodyKelo's Avatar
Default Urgent Help!
I just changed my timing belt, the secondary one. (I was some how driving that car with it completely broken) I idle at 900/rpms. Manual 2.3L 2000. My problem is i'm not gaining power. It's more in 3rd, 4th, & 5th gear when I accelerate my rpms go up but my speed doesn't. Sometimes it takes 2-3 times to get into 1st. I don't know if that has to do with my clutch or tranny. I'm at 190,000mil. I'll be honest I did a lot of redline pulls, that's what snapped my timing belt... I'm throwing out random info. just incase it correlates with my problem.
Old Oct 31, 2021 | 03:47 PM
Did you change both belts when you did the timing belt job?
Old Nov 2, 2021 | 03:59 AM
shipo's Avatar
If you drove the car with a broken timing belt then you have bent valves; have a compression test, or better still, a cylinder leak down test, performed to confirm the bent valves. Once confirmed, you'll then need to have the cylinder head rebuilt, or swap the head with one from a junk yard.
dbarajas96
Mar 3, 2014 05:21 PM
95AccordCar
May 4, 2010 04:11 PM
rbalmas2
Sep 28, 2008 06:37 AM
TACORICAN
Aug 25, 2007 07:29 PM
honda5o7
May 4, 2007 03:51 PM
