vtec solenoid gasket
Old Nov 10, 2008 | 11:54 PM
Default RE: vtec solenoid gasket
triple post!!!!!!!!!!!!!!
why wont the picture show????????????????
Old Mar 17, 2009 | 09:01 AM
accordchik98
Hey im having the same problem, my vtec solenoid is leaking as well. i have a 98 honda accord ex. Would the removal and replacement be the same on all accords?
Old Mar 17, 2009 | 10:38 AM
Welcome new member! Here's the 1998 spool valve, which is pretty much the same as most years up thru 2002.
The spool valve is #11, but the picture is kinda funny. In reality it's located more towards the right side of the car, closer to the throttle body & distributor. It might not be real convenient to reach the mounting bolts.
Old Mar 17, 2009 | 02:01 PM
accordchik98
Thanks!
Old Mar 29, 2009 | 05:32 PM
dcsmith's Avatar
Default Is this the item?
Mine is leaking. I took a few pictures of it to ask a friend of mine what it is and should I replace it or new gasket or rtv or what?
He said he never got the email. I ran across this thread while trying to figure a different issue. Of course I have reinstalled that thing without fixing anything.
Should I change the part or just get a gasket?
Any help would be appreciated.
David
Attached Thumbnails  vtec solenoid gasket-img_3388-2.jpg    vtec solenoid gasket-img_3393-2.jpg
Old Mar 30, 2009 | 07:46 AM
RTV has a risk of getting gunk in the tiny passageways of that valve. I'd get a new gasket.
Old Dec 5, 2019 | 08:51 AM
  #17
mister_two's Avatar
Just removed this VTEC solenoid from a 2000 Accord SE. Yes, the lower bolt is a PITA but it can be remove without removing the thermostat housing. A ratchet socket would not fit, I tried the slimest 1/4 ratchet I had but the t housing was still blocking it, even tried some swivel sockets, still didn't work. I tried a stubby 10mm wrench but it, or me, wasn't strong enough. Bought a offset wrench set from HF and that fit it was slowly rounding off the bolt. In hindsight I should have clean the bolt with brake cleaner to get rid of all the oil/grease and grime on it which would have help the wrench to get a better grip. But it finally worked with a longer 10mm wrench. It didn't have much room but just enough to crack it open. Will reinstall with new gasket.
Also there's third round gasket on a sensor attached to this solenoid. The sensor require a 21, or maybe 22mm, wrench to take off. Not sure if that is part of the oil leak problem but I removed this sensor to create more room to work and I notice a round gasket.
datman
Jan 22, 2018 08:59 AM
grannie613
Apr 20, 2013 09:08 AM
elvis1977
Oct 11, 2010 05:06 PM
c2k
Apr 5, 2009 03:50 PM
thunder_x
Jul 9, 2007 11:57 AM
