Warranty Expiring, What mods to do?
Old Apr 14, 2009 | 06:02 PM
ZionsWrath's Avatar
What suspension components should I be looking at?
I also added better braking to what I would like. I wouldn't be ordering anything for a month so I would like to make a list of what I should do and then narrow down what fits into my price range now and then leave the rest to get later depending what money I earn in the summer.
Old Apr 15, 2009 | 06:57 PM
ZionsWrath's Avatar
based on adivce of suspension wheels tires, i was looking at this
Wheels - Kosei K1 TS
Tires - Sumitomo HTR Z III
To be honest I don't know how to tell a good brand from bad one so I could use some guidance
As for suspension I know nothing of what I should be looking for. TireRack has 2 coil over sets: Eibach Pro-Street-S Coil-Over and H&R Street-Perf. Other than a difference of a fraction of an inch in adjustable height I'm not sure the difference other than $500 in price. If one is definitely better than the other I don't mind paying more but I would just need to know why.
Old Apr 18, 2009 | 10:40 PM
ZionsWrath's Avatar
Is bigger better for sway bars? I see most people are setting up with TL-S front and rear sway bars which are 20/27 mm. H&R is selling 22/28 mm rear/front sway bars...
Old Apr 20, 2009 | 07:38 AM
The balance between front-to-rear roll stiffness influences the transition between understeer & oversteer. But the roll stiffness at each end depends on the springs as well as the anti-roll bars. Suspension dynamics comes from all the hardware together as a system. If the rear springs are stiffer, then you need a less-stiff anti-roll bar to get the same roll-stiffness.
H&R probably chose those anti-roll bars to go along with a particular set of springs?
mchabukswar
Jun 17, 2011 08:55 AM
sir_nasty
Nov 27, 2007 11:44 AM
95AccordEXV6
Jul 6, 2005 09:49 AM
dinzer
Jun 13, 2005 10:38 PM
tam
May 22, 2005 11:44 AM
