Weird problem, hard to explain!
It can't be a slipping clutch because this just popped up when I got my engine swap. And my RPMs aren't rising look again and you'll see it stays at about 4,500. It has to be something that was changed when the engine was put in.
I suggest you check the physical throttle linkages if you haven't already. The accelerator pedal on these cars should not be hard to push. Maybe something is binding. There is a cheap spring under the gas pedal assembly -- it is seated correctly and not limiting pedal movement?
WHATTHELOUIS
Feb 5, 2009 06:17 PM
