Weird problem, hard to explain!
Old Sep 22, 2012 | 11:36 AM
  #21
matt2005's Avatar
Looks like a slipping clutch to me
Your is RPM going up but your speed is almost static.Definite slipping issue regardless of tranny MT or auto
Old Sep 22, 2012 | 10:59 PM
  #22
Cody_754's Avatar
Almost A Senior Member
It can't be a slipping clutch because this just popped up when I got my engine swap. And my RPMs aren't rising look again and you'll see it stays at about 4,500. It has to be something that was changed when the engine was put in.
Old Sep 23, 2012 | 01:52 AM
  #23
jkowtko's Avatar
I suggest you check the physical throttle linkages if you haven't already. The accelerator pedal on these cars should not be hard to push. Maybe something is binding. There is a cheap spring under the gas pedal assembly -- it is seated correctly and not limiting pedal movement?
Old Sep 23, 2012 | 01:50 PM
  #24
Cody_754's Avatar
I'll check for any conflicts with the cable today.
areyouben
Feb 7, 2014 01:43 PM
WHATTHELOUIS
Feb 5, 2009 06:17 PM
JkillaAcc02
Apr 9, 2008 10:19 PM
cybersnake
Apr 15, 2006 08:36 AM
calenatar
Mar 10, 2006 03:23 PM
