Where is my brake booster at??
Old Mar 21, 2010 | 03:10 PM
austinman3214's Avatar
Default Where is my brake booster at??
I've looked around the forums and the internet but cant get a straight answer here.
All I'd like to know is where my brake booster cable is??? (i'm seafoaming my car so...)
I hear its just the vacuum cable on the driver side near the firewall blah blah blah, still there are lots of cables in that area haha.
Old Mar 21, 2010 | 03:46 PM
kris_loehr's Avatar
It is the unit between the master cylinder and firewall on most cars.
Old Mar 21, 2010 | 08:25 PM
I need to know where the vacuum cable is, that is what side to disconnect and whatnot. A picture would be most appreciated. Your description is still fairly vague, keep in mind i dont know what the booster even is. let alone what it looks like.
Old Mar 21, 2010 | 08:34 PM
It's the big round thing behind the master cylinder, #1 here.
I think the windshield & cowling overhang forward, so you have to look back underneath to see it. Only the reservoir & the end of the master cylinder stick out beyond the cowling.
Old Mar 21, 2010 | 08:36 PM
Your vacuum hose is #6. As far as disconnecting it, what are you planning to do? Seafoam you could disconnect either end, maybe the engine-end is easier to disconnect. But then you'll want to find another hose to put in it's place & put the seafoam in there.
Old Mar 21, 2010 | 08:43 PM
this is exactly what i needed Jim! thanks. All i plan to do is seafoam the thing.
where do you get these diagrams? i could probably use this site quite often.
Old Mar 21, 2010 | 09:21 PM
www dot hondaautomotiveparts dot com
click PARTS
put in your car's information
I think the pictures are from Honda's electronic parts catalog, 'cause several on-line dealer parts departments have the same pictures.
Old Apr 29, 2018 | 07:32 PM
TroyH4's Avatar
I need help finding my vacuum hose on my 2010 Accord V6?
can you provide a diagram on where it might be located? My purpose is to clean m intake valves using CRC intake valve cleaner.
Thanks,
heathzx
Sep 27, 2010 11:00 AM
heathzx
Sep 20, 2010 12:04 PM
hondaptct
Aug 12, 2009 02:45 PM
status
Dec 28, 2008 10:30 PM
KGP
Jun 26, 2008 04:11 PM
