Where is the tranny oil drain plug for accord 2003 v4??
Old Mar 26, 2009 | 12:43 PM
teto
Default Where is the tranny oil drain plug for accord 2003 v4??
Hi All,
Where is the tranny oil drain plug for accord 2003 v4 Automatic????
I attached 2 pictures for drain bolt location (that's my guess). So please I need someone to confirm , is this the right bolt? Is this the right location?
In some forums I read it's next to the passenger wheel. But when I looked in my car, nothing was there.. The only one I can think it's , next to the oil pan from the driver side, as shown in attached pictures. Please advise!
Thanks in advance
Attached Thumbnails Where is the tranny oil drain plug for accord 2003 v4??-dsc04141.jpg   Where is the tranny oil drain plug for accord 2003 v4??-dsc04136.jpg
Old Mar 26, 2009 | 12:50 PM
finch13's Avatar
From what I can see you're correct. The tranny drain hold doesn't need a socket, just simply stick a 3/8" ratchet w/ or w/o an extension.
Refill using the dipstick hole.
Old Mar 26, 2009 | 12:52 PM
finch13's Avatar
#7 is the drain plug, which appears to be where you have it pictured.
Old Mar 26, 2009 | 01:13 PM
teto
Thanks a lot. I will give it a shot this weekend. So when I drain it..about 3 quarts will be drained and I will need to add 3 new quarts, right?
Old Mar 26, 2009 | 11:54 PM
teto
Is there a tranny filter need to be changed as well?
Old Mar 27, 2009 | 12:16 AM
finch13's Avatar
About 3 quarts, maybe 3.5? There is a dipstick for the tranny and it should be at the top mark on a level surface with the engine off.
No filter to replace.
Old Apr 6, 2009 | 09:50 PM
lvp0412's Avatar
If you haven't done the change yet, the drain plug is right in the center, up front, with a 3/8" square for a ratchet or breaker bar. (Looks like the green circle may be it) Easy to find. Refill is exactly 3 qts. (be sure to check it with the dipstick)
Change 3 qts, drive it for an hour, day, week, then repeat the process. You can only get about 1/2 of the fluid at each change.
YES, I found a filter that no one knew about! It's on top of the transmission case in a cooling line leading to the radiator, probably under your air intake tube below the brake master cylinder, and looks like a fuel filter with nipples and hose clamps on both ends. Easy to change, about $20 at a dealer, and you may have to order it. I found it, changed it, and cut open the old one and it IS a pleated paper filter that needs changing.
LVP - 03 Accord EX-L 4cyl
Attached Thumbnails Where is the tranny oil drain plug for accord 2003 v4??-photo2.jpg   Where is the tranny oil drain plug for accord 2003 v4??-photo1.jpg
Old Apr 7, 2009 | 07:30 AM
Some confusion...
Previous 4-cyl Accords (2002 & earlier) have the engine facing the opposite direction. So the tranny is not only in the other side of the engine bay, but for the auto-tranny the drain plug used to face away from the engine, not towards it.
There's always people that think all Accords since 1977 are just the same as each other...
Old Apr 7, 2009 | 08:17 AM
teto
I did change the tranny oil and the plug as finch13 said. It's # 7 , which is as shown in my attached question pictures.
Old Apr 7, 2009 | 10:11 AM
Yeah, exactly. My post was more for the benefit of other people who read this, who have Accords from 2002 & earlier.
alltime3rdwheel
Dec 31, 2012 10:46 AM
jon02accord
Mar 26, 2008 10:54 AM
canjoh
Feb 15, 2008 11:51 PM
natesriv
Oct 31, 2007 08:44 AM
desi01
Jun 24, 2006 05:49 AM
