wierd transmission problems
Old Mar 29, 2007 | 11:04 PM
studentmechanic101
Default wierd transmission problems
Hi everyone, I have a 93 accord with an automatic 4 speed. It has the wierdest transmission problem, if you put it into the drive 4 positiotn it actually starts off in 4th gear. If you put it in drive 3 it starts off in 3rd gear and so on. All of the gears work perfectly if you shift it manually. I dont know if this is a major problem or not. If anyone has any ideas, they would be very helpfull. Thanks, Matt.
Old Mar 30, 2007 | 08:42 PM
Default RE: wierd transmission problems
There should be a Trans Control Unit (TCU) diagnostic code stored. Short service check connector per following link and read the D4 (trans position indicator) light flashes for the code.
http://www.troublecodes.net/honda/
Post code/s back and your problem can be addressed.
Old Apr 3, 2007 | 06:43 PM
studentmechanic101
Their are no codes present for some reason. I dont know what now but I think I might be looking at a new trans.
Old Apr 3, 2007 | 07:21 PM
sir_nasty's Avatar
I doubt you need a new tranny.... the reason I say that is because each of the gears works fine it's just shifting between them that isn't working.... with no code stored I'm thinking it's a problem with either the TCU itself or a shift sensor of some sort.....
grimrepo
Sep 2, 2009 11:05 PM
Mrandy
Jan 1, 2008 06:25 PM
nixalot
Aug 10, 2006 04:54 AM
vi3tpride93
Jul 2, 2006 03:17 AM
shill1234
Oct 25, 2005 01:51 PM
