Window gasket wapring???
Old Jun 17, 2008 | 01:41 PM
tlhfirelion's Avatar
Default Window gasket wapring???
See pic attached. This corner of the window seal is odd. It seems to of just curled in on itself and now half the time I roll up this window the window pops out and sticks about ha;f an inch out of this part of the window trim. I have checked the guts of the door and the window in on track, not coming off, and is lubed up and operating ok except for this portion of the window. Is there any way to fix this or what needs to be replaced to repair this issue? If I do need a new trim piece any idea what part number it is?
97 honda accord SE 4 banger auto is my vehicle.
Thanks!
[IMG]local://upfiles/15122/B50D89FDF2194CA3ACD4680DD1D7583E.jpg[/IMG]
Old Jun 17, 2008 | 02:24 PM
Erinsaccord's Avatar
Default RE: Window gasket wapring???
No answers for you, other than my 1994 does the same thing, though not quite as much.
Old Jun 21, 2008 | 06:51 PM
2slo4u
My 99 just started doing this. Its quite aggravating.
I just roll the window down a little, Pry the seal out. It's good for about 2 days. LOL
Old Jun 21, 2008 | 11:22 PM
My 95 accord does the same exact thing.
Old Jun 22, 2008 | 08:50 AM
The window guide (glass run channel) is replaceable, but door panel and window must be removed to access. Download a shop manual for guidance. Not hard, but you can damage door panel or regulator if you do this job improperly. It could also be a slight window misalignment due to improper installation.
ravenr106
Oct 21, 2011 06:08 AM
ravenr106
Oct 20, 2011 05:32 PM
2006accordexl-passmirrorbroken
Apr 12, 2010 03:01 PM
mmazb3
Nov 26, 2007 03:16 PM
thunder_x
Jul 9, 2007 11:57 AM
