windshield wiper fluid not working
Old Dec 23, 2014 | 12:56 AM
56belair's Avatar
Default windshield wiper fluid not working
I need to isolate why my windshield wiper fluid isn't spraying out the nozzles. When I pull the lever back I don't hear a motor engage, I don't suspect the nozzles are clogged or the tubing in the hood is bent. I took off my bumper and I see the pump. Doesn't seem easy to replace at first glance.
Thoughts on this?
Paul
Parker, Co
Old Dec 23, 2014 | 09:20 AM
Need model year, trim of your Accord.
Wiper motors are prone to fail w/ age and require replacement. You can confirm wiper motor is at fault by checking for battery voltage to wiper motor when wipers are commanded.
Old Dec 23, 2014 | 10:00 AM
Can you remove the "outlet" hose from the washer pump and blow through it? Still won't tell if there is a "break" in the hose but should confirm there is no blockage.
Also with the hose off, turn the washer on and be sure you get spray from the pump.
As TX said, from here we are going to need a bit more information.
crashdummie
Nov 23, 2013 01:27 PM
BMWright92
Jan 24, 2013 06:30 PM
BHoward711
Nov 17, 2010 10:05 AM
luey42n
Nov 19, 2005 09:30 PM
Jirviss
Apr 29, 2005 03:32 PM
