AT wont shift without releasing gas pedal
Old Jul 1, 2011 | 06:15 PM
piggylover1985's Avatar
Originally Posted by PC96
Honda can't make very good auto transmissions apparently.
Seriously though, older GM's use a throttle valve cable (ie. downshift cable) and they are adjustable on those, not sure about the older Accord setups. Improper adjustment will cause all sorts of weird shift point issues, though. It's worth looking into.
Yes older Accord shift feels and timing can be adjust by TV cable, 98 up are computer controlled. Every manufactures have their weak point. 98-02 Accord, 99-03 Odyssey,99-03 TL,01-04 Civic have issues with their auto trans like overheating converter. GM's got common issues with their trans too like "trans component slips" on the FWD 4T65E 97 up, lockup problem cause internal melt down with the Northstar engine 4T80E 93-04
04 up Maxima,Volvo,Saab with the AW55-50 SN with hard shift problem cause by worn out valve body. Dodge 604 FWD with blown diff, RWD 500/518 with gov pressure sol & sensor. Ford Taurus/Winstar/Sable with converter splines stripped out cause it "no move". Toyota with the U140 in the Rav4/Corolla/Vibe slips in 3rd because the TCM failure.
Old Jul 1, 2011 | 06:21 PM
Originally Posted by FL4T
not sure whats going on, trans fluid seems to be at a normal level and no lights or anything on the dash, but the car wont shift normally,
it will build up to 2.5k or 3k rpm and stay there until i let off the gas,, does that in a couple different gears and sometimes feels like it downshifts once i release the gas at times
recent seafoam of vaccuum line, gas and oil crankcase, new plugs but thats it
You can't get it to rev past 3k in gear even if you floor it ? Sounds like engine problem there.
Old Jul 1, 2011 | 06:29 PM
Just check like you normally do for transmission codes. If a "hidden" code is stored, it will flash like a normal transmission code.
Old Jul 1, 2011 | 06:35 PM
FL4T's Avatar
yeah, i just changed plugs and they were very carbon covered, one cylinder may have oil in it, i feel like its misfiring but the ecu has no misfire codes..
it also jumps back and forth between 1k rpms and 1700ish when in park... idle is fine when in D4 while stopped
Old Jul 2, 2011 | 06:01 AM
Check IAC valve, map sensor, TPS , and vacuum for leak.
Old Jul 2, 2011 | 12:15 PM
Sorry, confused your post with another post....you have the toggle switch on your service connector.....
Old Oct 13, 2020 | 11:15 PM
  #17
Justin West's Avatar
Default Help
My sisters friend is having this same issue with having to let off the accelerator to get the car to shift on the highway. I see alot of post about this but no post saying what is actually causing it or how to fix it. Was there something I missed? Is there a way to fix this or a definite reason why this is happening?
Old Oct 13, 2020 | 11:21 PM
  #18
This thread is pretty confusing with different folks asking questions. Can you start a new thread and give us some information about the vehicle. Any work done on the car. Also check for codes with an obd2 scanner or obd1 method depending on the vehicle.
dpz1
Apr 17, 2012 09:05 AM
DClark7
Sep 13, 2011 04:50 PM
Lokheed
Mar 18, 2009 04:49 PM
thedaveman89
Nov 26, 2008 03:37 PM
cklanke
May 25, 2007 09:32 PM
