Yellow Check engine light and maintanence question
I have a 1993 Honda Accord ex-r and the yellow check engine light has been coming on while driving down the highway. It only comes on after driving for awhile down the highway. In the city it never comes on.
I have also noticed that it has a hard time starting from time to time, where it seems to get flooded and I have to hold the pedal to the floor to get it to run.
The only maintenance I do to the car is change the engine and tranny oil on a regular basis. Maybe I should start doing some other maintenance instead of just waiting for something to break down.
Any ideas on what might be causing the check engine light to come on? Why the hard starts sometimes? O2 sensor?
What are some good maintenance things to do? Spark plugs? I don't think I would want to attempt a timing belt change, even though it probably needs it.
Thanks for the help in advance.
https://www.hondaaccordforum.com/for...ht+1993+accord
That code is stored in the engine computer, so you can check for code(s) now.
Post the codes you get on here.
To erase codes, you remove the 7.5 amp backup/radio fuse in the engine bay fuse box for a minute. If you get more than one code, you can clear the codes, then drive until the CEL turns on again and check for the current code.
shoey
Feb 9, 2013 05:22 PM
78gaw
Jan 20, 2010 09:45 AM
