The Dreaded Exhaust Buzz(Solution Inside)
Old Jun 23, 2010 | 05:27 PM
corvetteking's Avatar
Default The Dreaded Exhaust Buzz(Solution Inside)
This is a service bulletin from honda about the Exhaust system buzz in 94+ 5th generation accords... Didnt know whether to put in here or DIY... Mods can sticky and move to appropriate section...
To fix the issue more than likely you will need to replace the 6 or 8 inch section of exhaust mid pipe. Honda calls it the exhaust buzz kit.
Here is the bulletin:
Here is the parts information:
Exhaust mid-pipe fastener kit:
Part Number: 18010-SV4-305, H/C 5027362
(Kit contains two gaskets, four flange bolts,
four springs, and four self-locking nuts.)
Old Jun 25, 2010 | 08:32 PM
dre707's Avatar
do you think maybe some new megan headers and test pipe will stop the buzz? my accord does the buzz at 1800rpm i thought it was the transmision
Old Jun 25, 2010 | 08:40 PM
g22cd5's Avatar
Supper Moderator
99.9% of the time its heat shields. check them be4 buying any exhaust parts
Old Jun 25, 2010 | 10:45 PM
dre707's Avatar
i wanna get the headers and test pipe anyways justwanted to know if that will stop the buzz
Old Jun 25, 2010 | 11:09 PM
Its either the heatshield is loose, or that the parts in that mid section are worn out... Try tightening the heatshield first, if it still happens, try the kit... If your test pipe replaces the midpipe, then it probably will fix the prob...
Old Jun 26, 2010 | 12:26 AM
dre707's Avatar
i dont know much but is there a midpipe between the headers and test pipe? cause i dont know how it all connects
May 27, 2019 01:20 PM
jpilk99
Jan 2, 2015 11:26 AM
cuda6pak
Oct 5, 2013 09:38 AM
kumazam
Mar 29, 2010 07:11 AM
gimme789
Mar 25, 2008 01:41 PM
