New throttle body, help please
I have a 97 honda accord, its an automatic and im having trouble finding a bigger throttle body for it. I recently bought a blackworks racing throttle body but it didnt work because i have two throttle cables and it only had the one switch for one cable. I think the reason i have two cables is because its an automatic. Does anyone know where i can order a new throttle body for an automatic transmission or if they even make one?
please help me out if you can, thanks.
1997 Accord f22b1
1997 Accord f22b1
Unless you change your cam(s), the exhaust, the upstream intake plumbing, and the intake plenum to increase the overall systemic capabilities of your engine (changes which will give you extra high RPM power but will most likely reduce your midrange torque by a very noticable amount) then the single addition of a larger throttle body won't do diddly for the engine.
Using low-restriction intake components, like air filter, short-ram intake, etc. can only improve things to the extent that the stock stuff is restrictive. Traditionally, Honda 4-cyl engines don't have very restrictive stuff so it won't improve as much as it would for some other car companies.
Yup, you're most likely better off with the factory throttle body.
ghostpilot
03-04-2012 12:17 PM
johnnym
07-13-2009 08:11 AM
