resetting the ecu
Old Apr 25, 2007 | 12:33 PM
1996AccordLX's Avatar
Default resetting the ecu
Why do you have to reset the ecu after you put on a cai or sri?
Old Apr 25, 2007 | 12:56 PM
sssexy70's Avatar
Default RE: resetting the ecu
Your ECU is self teaching. And since you have installed an item that will draw in so much air it needs to recalculate the fuel to air ratio for best efficiency.
Old Apr 25, 2007 | 04:55 PM
Honda_Dude's Avatar
how do you reset the ecu?
Old Apr 25, 2007 | 05:46 PM
sir_nasty's Avatar
either pull the main fuse (#15 under the hood 7.5amps I believe) for a couple minutes or just remove the negative battery cable for a few minutes... if you have a newer car with a "anti-theft" stereo be aware that you may need to get the unlock code from the dealership after you do this reset
Old Apr 25, 2007 | 06:06 PM
deserthonda's Avatar
ORIGINAL: Honda_Dude
Go to the DIY section top of page ( how to clear ecu )
Old Apr 26, 2007 | 11:55 AM
And if you don't reset it, then it will throw some code and the light will come on right? And if the light didn't come on, then it's all fine?
Old Apr 26, 2007 | 02:56 PM
sir_nasty's Avatar
If you don't reset it then the computer will run based on what a stock intake does so you don't get the full potential for economy and power.... It typically won't throw a light though....Since the computer is constantly "learning" it will eventually (over a long period of time if you don't reset it) adjust to what you have on, I put a CAI on my civic and didn't reset the computer and it was fine....
Old Apr 27, 2007 | 12:14 PM
Ok, i think i get it, thanks guys.
99HondaAccord
Mar 31, 2009 10:36 AM
razcob
Dec 22, 2007 06:12 PM
2007SEV6
Sep 5, 2007 02:52 PM
Bombadillo
Jun 21, 2007 09:16 PM
Antarctica
May 29, 2007 01:57 PM
