2009 Accord EX V6 code P3497
Old Mar 8, 2020 | 11:14 AM
moeheston's Avatar
Default 2009 Accord EX V6 code P3497
Hello Everyone, I have a 2009 Accord Sedan EX V6 3.5. I had an oil leak at the Front Variable Valve Timing Solenoid (VVT) and replaced both the body seal and lower seal with the screen within it (see picture). The good news is I fixed the leak the bad news is I induced a code P3497 (cylinder deactivation system bank 2) after reading many threads which helped me to understand what I had, the fix was to ensure oil level was correct and replace the oil pressure switch on bank 2. I did an oil change along with the Oil pressure switch change however after driving for 20+ miles, the check engine light comes back on with the same P3497 code. After several attempts to rectify, now the car went into limp mode after 40 miles of driving with the same P3497 code. Any feedback would be appreciated.
Old Jan 3, 2021 | 11:07 PM
rhettchristiansen@yahoo.com's Avatar
Default Help!!
I did the exact same thing and can’t seem to figure out what the problem is.
Did you get this figured out??
Old Jan 14, 2021 | 06:21 PM
mpete1155's Avatar
Did you figured this out. I got same issue to resolve.
Old Jan 14, 2021 | 09:37 PM
I never got a reply but After trying everything I could think of I replaced the VVT module and it fixed the issue. torqued the 3 bolts to 8 ft. Lb.
Old Feb 8, 2024 | 10:49 AM
Jaace01's Avatar
Same thing on my 2012, it only does it after it warms up and driven for a while then I get the code 3497 and the sensor is good, so I'm going to try replacing the solenoid.
Old Feb 17, 2024 | 10:02 PM
Jaace01's Avatar
I didn't replace the solenoid all my sensors were good, was told by someone more knowledgeable in Hondas than me but, sometimes the small holes and passages on that front solenoid can get clogged with debris and sludge built up over time so I took the solenoid off where the gasket and the screen is, cleaned it real good with some throttle body spray while I had the drain plug and oil filter off, and I just let it sit overnight to drain.
and before I put the screen and gaskets back together I poured a little bit of oil on it.
I've been driving it for a week now and the code hasn't come back.
GreyD
Jan 26, 2020 09:09 AM
JS1970
Jan 3, 2017 09:49 PM
Linda P
Jun 13, 2012 04:40 PM
00AccordLX5spd
Aug 3, 2009 09:10 AM
Mayne
Nov 12, 2008 03:17 PM
