2017 6 speed auto trans
Old Jul 17, 2025 | 12:36 PM
jfo's Avatar
jfo
Default 2017 6 speed auto trans
Hi All,
New (very recent) owner of 2016 Accord EXL V6 w/ 6 speed automatic. The car has 104K and I purchased from a friend who had kept meticulous service records. I am draining the transmission and installing the prescribed 3.3 quarts of DW1. I have previously tried to check fluid levels and the dipstick is almost impossible to get an accurate read. So I indexed a plastic jug at 3 qt 10 0z and measured it twice. The drain pan emptied into jug, shows overfilled by an estimated 16-18 oz. My question is; can I drain beyond the 3.3 quarts (only about 30-40 minutes level on ground) or do I replace the amount that came out? The last service was at Honda shop and done about 10k ago, prior to my acquisition. Shifting has been a tiny bit wonky, hence the current service. My inclination is to go with the 3.3 qt and do some limited driving and see where things are.
The reason I get on these forums is the wealth of previous experience and knowledge. I would appreciate any and all feedback.
For the record, I had a (also recently acquired) 2007 Odyssey van w/ same drive train and it shifted similarly at first and got much better after 3 cycles of DW1 drain and fill. Did the timing belt,WP, valve cover gaskets, and valve adjustments, among many other repairs. Not bragging, just illustrating skill set.
Thx,
JFO
poorman212
Nov 13, 2015 06:14 PM
justin_l_
May 28, 2014 05:15 PM
Mandy
Jun 2, 2012 12:18 AM
Low Miles
Jan 6, 2010 12:43 PM
