Car ramps
Old Sep 13, 2007 | 12:33 PM
y9pema's Avatar
Default Car ramps
anyone know of a good set of car ramps for a lowered accord. finally got my suspension work done and want to change my oil and the car is low. heard of people puttin boards infront of lifts and ramps to make it work, i'm confused like a 2x8 or wider, and does this really work. thanks
Old Sep 13, 2007 | 05:20 PM
RTexasF's Avatar
Super Member
Default RE: Car ramps
My car is not lowered but requires boards in front of standard ramps so it doesn't scrape. I went to Home Depot and bought an 8 foot 2X6 from the best wood they had. Then it was cut in half. To change oil I put out the ramps and put the 2X6's in front of them checking carefully that things are lined up. Zip! Up it goes and I'll bet you can achieve the same without scraping. The angle of the ramps determines how long the approach boards need to be.
The lower the car, the longer the approach to the ramp.
Old Sep 14, 2007 | 11:30 AM
y9pema's Avatar
yeah this totally worked i used like a 2x10 bout 3 ft long drove up on those then the ramps. still was a pain getting under the car for the filter, but it was done.
Old Sep 15, 2007 | 03:47 AM
s20700134's Avatar
ive seen these small ramps before. there so you can raise the car enough to get a regular jack underneath. im pretty sure they are called "tomioka racing super slopes" http://www.tomiokaracing.com/ should give ousome info. seems kinda pricey tho when you could just use a couple of 2x4s.
Old Sep 15, 2007 | 11:03 AM
RTexasF's Avatar
Super Member
ORIGINAL: y9pema
Your are correct, it was 2X10's that I bought. Works fine for me.
Old Sep 15, 2007 | 11:04 AM
RTexasF's Avatar
Super Member
ORIGINAL: s20700134
2X4's are too small, go larger for more strength.
Old Sep 16, 2007 | 04:02 AM
s20700134's Avatar
im just talking about 2x4s to set on the ground to roll the car onto, then be able to use a regular jack.
HondaPete14
Feb 15, 2012 05:34 PM
njmodi
Dec 16, 2011 10:06 PM
atom1
Jan 19, 2010 03:58 PM
junyea
Jul 26, 2007 03:12 PM
jackkpts
May 12, 2007 08:34 AM
