Do I need to replace water pump (07 Accord 4 cylinder)
Old Nov 28, 2013 | 04:46 PM
manbeing's Avatar
Default Do I need to replace water pump (07 Accord 4 cylinder)
My 07 Accord (4 cylinder) has hit 105,000 miles. The maintenance indicator is on and the manual says 'replace the timing belt', but I know 07 accord is equipped with a timing chain that isn't required a service for the life time.
I just wanted to know if I will need to replace the water pump this time?
Old Nov 28, 2013 | 05:02 PM
Correct, the 4 cylinder has the timing chain. However, you still have the drive belt. You may want to change the drive belt at 105,000 miles if it has never been changed.
You don't necessarily need to change the water pump unless there was a problem. The water pump is easily accessible on the drive belt side.
Old Jan 3, 2014 | 09:30 AM
amccinns's Avatar
Yeah, water pump is basically a replace when needed issue. It's fairly inexpensive and mine lasted forever on the last accord I had for 9 years before this one.
CHUCKW
Apr 24, 2015 06:07 AM
PinkFloridaFlamingos
Aug 27, 2011 08:08 AM
piggylover1985
May 27, 2011 05:28 PM
00AccordLX5spd
Aug 27, 2007 10:48 AM
oldaccordman
Feb 4, 2007 04:46 PM
