Does this picture indicate bent valves?
Old Aug 28, 2021 | 07:19 AM
Gmpisawesome's Avatar
Default Does this picture indicate bent valves?
I have a 2008 accord v6 manual. Cylinder 6 is misfiring. I took off the valve cover and the “T” means the rocker is tight against the spring and “L” means I can wiggle it. Somethin seems……fishy…..on that misfiring cycinder. Guessing that means I have a bad valve?
Old Aug 28, 2021 | 08:25 PM
I'm not sure I'd bother working it out from the firing order. Just rotate the engine (forwards) with a socket on the crankshaft & see if they get loose when the respective cylinder comes to TDC-compression.
jeffbantle@gmail.com
Aug 28, 2019 07:51 AM
remix919
Jan 4, 2017 04:00 PM
denierlexiese
Aug 31, 2015 10:22 AM
KingReset
Oct 20, 2014 06:37 PM
poynterandy
Jul 27, 2011 08:02 AM
