tranny slipping
Old Oct 25, 2007 | 10:23 PM
SteveO_f22a's Avatar
Default tranny slipping
First off, im kind of a noob. so i dont really know that much bout hondas
so i got my car back from the impound (impounded on account of incarceration), and it was sitting in my drive way for bout a month. i went to start it up today. Nothing. no turn over, no click, no nothing. turns out my battery was a dead curcuit. easy fix, i got a new battery. now i have no money...The problem is that before i let it sit, my tranny was only getting 2nd and 4th. now it gets all four gears. i had originally diagnosed that my tranny was just gummed up, and that i should also change the filter and all fluid. but i dont know how to do any of this. any help would be GREATLY appreciated, seeing as how it is going to help get my baby back on the road.
Old Oct 26, 2007 | 10:10 AM
HondaRacer4Vtec's Avatar
Default RE: tranny slipping
If the tranny was truly gummed up, you might want to do a complete auto tranny flush treatment. Anyway if you do a serch on the forum peolpe have explained how to change auto tranny fluid. People say you should do a 3 refill and drain process. I only do it once, to much money for my pocket. BUt on the process of helping you i cant, you havent given us your model, year, trim. Also just a tip for you remove the turbonator before you **** up your engine.
Old Oct 26, 2007 | 10:16 AM
falkore24's Avatar
I agree with HR4. Multiple changes, but no power flushing on Honda AT's!!! 1 change is good for maintenance, but if there is a problem, it's best to change the fluid, drive the car for 5 miles and change it again. Do this for a total of 3 changes to get 70% of the crap out. Please change your signature to show all necessary info. If all maintenance is needed, I'd change all fluids, belts, replace rubber hoses with silicone, flush the radiator twice with vinegar and water and flush it 5 times, use Marvel Mystery oil and engine flush and after the next oil change, do Seafoam.
Yeah ..... the turbonator has no chance at all to make any gains. It can only cause problems.
Old Oct 26, 2007 | 11:12 AM
00AccordLX5spd's Avatar
Registered User
x3 on removing the Turdbonator
Check out the DIY section for instructions on the tranny drain & refill.
MoeSoJdm215
Oct 24, 2012 06:40 AM
larrypac99
Jul 13, 2012 09:35 AM
yeding
Jan 16, 2009 06:52 AM
kornfox
Mar 29, 2007 05:37 PM
Mechhead
Jan 24, 2007 10:19 PM
